I'm assembling a mercruiser 350 from 96(pre vortec) and I found this plate between the manifold and the carburetor(Weber 4 b). I can't find the plate in the manual and I wonder what it's for and if I should keep it.
It was originally used as a insulator. Gasket below and gasket above it. They use to just use a thicker gasket. Just someone's brain bubble. BTY, vortex engines started in the late 80's. Yours is just a later one.
It is insulator for heat. Weber carburetors suffered very much from heat coming from the engine into the carburetor. Just continue to use the insulator, with new gaskets. You are correct, the service manual does not show the plate, but the parts diagrams do...
