please dont laugh
Chaparralboater
Re: please dont laugh
they are rubber hose/channels that your driveshaft is going threw. They go from your transom to your outdrive. more will chime in. Do you have an inboard/outboard
Bt Doctur
A rubber coupling used for anything that goes up and down or goes left and right.
exaust, input shaft, shift cables.
stonyloam
Here they are: http://www.mercruiserparts.com/Show...91/9.png&inbr=1017&bnbr=50&bdesc=BELL+HOUSING
#13 is the watertight connection between the gimbal housing and the movable bellhousing that the outdrive attaches to. #19 is the exhaust bellows that directs the exhaust gasses out from the gimbal housing to the exhaust ports in the outdrive
#26 here is the shift cable bellows that keeps water from leaking in around the shift cable http://www.mercruiserparts.com/Show.../5.png&inbr=1017&bnbr=30&bdesc=GIMBAL+HOUSING
This is for a Mercruiser,but the principal is the same with others. They are used to make a flexible connection.
JoLin
Don't feel bad. I'm shopping for a boat and had a guy on the phone last night...
When were the bellows changed last?
The what?
The bellows- the boots.
Huh?
The rubber accordion things that keep the water OUT of the drive and transom...
Oh! You mean the tubes!
<sigh> Yeah, the tubes...
jfrey8899
It is a sterndrive. And that is what I thought they were. In order to change them off comes the drive right?
We are going to need some more info here....
Year,
manufacture of drive,
size of engine,
then we can help you. Too little info. Different set-ups out there
jfrey8899
1971 sea swirl with a mercruiser 140 sterndrive
jerryjerry05
Yup the drive comes off.While it's off change the shift cable and bellows and make sure the gimbal bearing is good.Then change the impeller and oil.
It's actually easy to do.Just take pics as you disasemble.J
