How do the fuel supply systems work with these engines? I've heard someone say that the tanks are pressurized. Is this true?
I know my current Force 125 has a diaphragm fuel pump on the side of the block that draws fuel from the tank and pressurizes it to fill the carb bowls. Are the OMC engines different? Are there different fuel systems used from the 50's through to the 80's or are they all pretty similar?
Could I run an OMC engine from a small container of fuel for diagnostics? When I was troubleshooting I ran my Force from a quart can. A 125 HP will suck through a quart pretty quickly!!! even at idle. I was surprised at what a guzzler it is. Curious how the OMC fuel systems work.
thanks in advance.
thanks in advance.
