Texasmark
- Joined
- Dec 20, 2005
- 14,795
Help me understand this Roscoe and "gss036" if you see this, please, or anyone else who has the answer.<br /><br />This DeCarb thing is new to me. Till I popped onto this site a couple of weeks or so ago I never heard of it.<br /><br />On carbon, I always associated it with leaded fuel. When the lead left, that's when my engines cleaned up.<br /><br />Last 2 cycle engine I had apart was a '75 70 hp rude (in the late '80's) and the only reason I was into it was because it siezed up at WOT cause I had just bought it and it had no alarm and it had a frozen closed thermostat, and I had no way of knowing........they never stick open!!!! <br /><br />(On this site I noticed that some recommend you change them every 2 yrs. So I guess when you buy a used engine the first thing you do is to put in a new one......or trash the old one, like engines (Merc especially) ran for a lotta years "without one".)<br /><br />Anyway what am I fighting here? Is it gum and varnish in the fuel (carb innards particularly) caused by motors sitting alot, and/or built in fuel tanks that don't get fresh fuel cycled through them very often?<br /><br />The oils are supreme as compared to early boating years so they can't do anything but help the situation rather than hurt it. And with higher fuel oil ratio's there's less oil to burn up and clog passages.<br /><br />The fuel gets whacked all the time but I think fuel is just an excuse. Everything I have runs better on the fuel available today and when I can run a sparkplug 100,000 miles (Bosch platinum in GM), pull it out and have little or no buildup of whatever, that speaks pretty well for the cleaning ability of today's fuels. Also I don't remember the last time I stuck my nose in a can of gas over 6 months old and smelled varnish! <br /><br />My Dodge runs conventional Champions and I run them 40 or 50,000(with one gapping)...recommended to be changed at 30,000 but a waste of money... and they come out with minimum contaminants. I remember a '72 Chev wagon with a 402(396) big block that I had, and I would have to change them every 10,000 running leaded gas.<br /><br />So that leaves the EPA. I noticed the other day, a chart showing that they are requiring outboard motor emissions to drop about 10% per year and on my 2002 Merc, the chart was at about 60% of the emission level that existed when they went after outboards. <br /><br />So is there something in the engine that has drastically changed to cause "carbonization" requiring decarbonization caused by the EPA requirements?<br /><br />Would really like an answer?<br /><br />Now I assume if you troll a lot with a large engine, or run a big rig with a small engine where it is loaded heavily all the time, or a high performance rig run at WOT for long periods of time, or operate in a very cold climate, I could understand burnt oil in the explosion and exhaust chambers that may need removal.....after a long time running.<br /><br />Bet others would like to know also.<br /><br />Thanks,<br /><br />Mark
