Re: PLEASE HELP!!! 1982 OMC Stern Drive 800 I/O
If you have the thru transom cable and steering rod, then you do not have the intermediate steering gear and shaft, so you could disconnect the attachment on the side of the outdrive and try to swivel the O/D. If it does not swivel then you are bound up inside the swivel housing.
If you have OMC TruCourse steering? The double cable that has a drum at the front and the back?
You would have had to pull the steering shaft out, at the right rear of the intermediate housing. Did you check the forward bushing where the shaft rides in the IM housing? Did you put the rear bushings and spacers back in right? If you had the shaft out to replace the cable, it could not be seized due to corrosion or lack of lubrication.
To determine, remove the outdrive and carefully hold it aside. This will disengage the drive from the steering gear on the shaft. If the wheel does not turn very easily and smoothly, then your cable is binding or the shaft is binding.
If it does turn easily then your problem is in the swivel housing in the outdrive. You'll need to have the O/D removed anyway to address this.
Is this a saltwater boat?
