I have a temp sender that mounts to the outside of the power head, there is a z-type bracket that holds the sender to the head and a wire that runs to the gauge. I thought this sender may have gone bad as I was getting faulty readings at the gauge, we tested the gauge by removing the wire and grounding it out the gauge read full-hot. When I installed the new sender that I got from Napa it read the same as the old, key on 160 degrees cold. Any ideas about what is going on? Need more details?
