Re: Please help identify this OMC Stern Drive!
Looks like a 400 series lower in the first pic.
13 spline propshaft = 400
15 spline propshaft = 800
Regardless, that silver paint was late 1984 to 1985, which is indeed mechanical shift stringer, and the impeller is on the bottom side of the upper unit, no impeller on the lower unit.
However, the part you need to be most concerned about is the shift cable that is missing off that lower unit. It's $750 for a new cable, and I don't see the rack/pinion assembly that the cable goes into on the lower unit either (those parts aren't available new anymore)- hope that stuff is in the boat somewhere.
