Ok so a couple things I need help with,
I just got this 1967 Larson with the motor for 100 dollars from a co-worker that didnt want to mess with it. Problem is the motor turns but will not start. He bought it about 6 months ago and said it ran when he purchased it but never did anything with it. The motor backfired twice and wont start. I just found this wire broken on this block - image below - ( dont know what it is ). Is this a ground? Would it prevent the motor from starting? Also I want to get a manual for this motor but this is the only identification marking I can find on the motor - image below - so I dont know what model this engine is to lookup parts or the proper manual. So with that in mind im not sure what is the proper gas/oil mixture for the motor, 2 stroke / 4 stroke etc.. Im using the gas thats in the tank already but it could be bad gas and im not sure. Im attaching images of the motor for identification. Any information would be greatly appreciated. Thanks
