Please help me 1982 75hp johnson trim tilt
Greger7413
I am working on a 1982 johnson 75 hp formula J75TLCNB. I have got everything working and the trim tilt from the battery but i cant figure out the wiring to the switch and relays. Everything works but the diagram does not really show a clear way to do this. I have the relays and wire boxes but have no idea how they ground or what they do. Can anyone help me
Is it a 2 wire tilt motor or a 3 wire ?------Wiring diagrams are found on line using ---google----I am sure.
Describe what is in the " relays and wire boxes "-----Does it contain 2 wee square boxes ( relays ) or one solenoid ?----Any pictures of the wiring ?
Crosbyman
previous drawing is a 3 wire trim motor ...working of one selenoid .. if you have "relays" shouldn't be a 2 wire operation???
as per request ....can you post pictures
