Prop swap. Hub kit?
Hi everyone, I'm currently trying to change out my original 19 pitch prop with a 21 pitch. Im replacing the omc prop with another omc. The new prop is "deeper" than the old and the trust washer is a pretty sloppy fit in the the new one as where the old one it fits freely, but not nearly as much play. With the prop being deeper, the original spacer is too thick and if i take the spacer away the prop nut will bottom out on the splines. Will a hub kit fix my probem with the spacer and the thrust washer? If so what hub kit do i need? Its a 1988 cobra drive with a 5.7 chevy. Part # from the "new" prop is 391202 if that helps any. Any input is appreciated. Thanks everyone
