Please help me prop my 1996 Force 40
hosmer
Hi all I currently have I believe a 14 pitch prop I think it may be 10 3/8 x 14 I also had a 15 inch prop tell me what you think the best prop size would be I know I need around 5200 RPMs but I don't have an RPM gauge on the boat looking for overall just good top-end and would like to pull the kids on tubes once in awhile old props were aluminum and I am going to stainless thanks
hosmer
Please help me prop a 1996 Force 40
Hi all as indicated I have a 1996 Force 40 I currently have 2 aluminum props one is a 14 pitch the other a 15. I was told a 10 3/8 by 13 would be a good choice looking for the most I can get out of this motor and I am upgrading to stainless thanks in advance
roscoe
Simply can't answer that with the info given.
Kind of like asking what shoes to buy for your wife who is 28 years old and has blonde hair.
Yegboats
How do the 14, and 15 pitch props perform? Do you have a tach?
roscoe
He doesn't have a tach, and we don't know what kind of boat it is on, or how much it weighs, or how the 14p or 15p prop performed.
I wouldn't spend money on stainless.
I would go to a 4 blade aluminum long before I went to stainless.
jerryjerry05
You HAVE to have a tach to do it right.
​They sell an item called a "Tiny Tach" or something similar.
I bought one for $16 Amazon or E-bay
It hooks to a plug wire and gives really good results.
The stainless or aluminum??
Stainless has less flex and will perform better.
But if you run in shallow water and find the bottom often you might want to stick with alum.
The stainless won't give as quick as alum. and can break shafts?
If you decide SS the pitch will be different than alum.
OR??? Contact Michigan Propeller and give them the info on the motor and the boat.
They have a prop finder service and can tell you what you need.
hosmer
Thanks for the info guys sorry the boat is a tracker super guide v16 not sure what it weighs can't be much being aluminum
