Re: Please Help! Mercruiser shutdown
Welcome to iboats....
First put that flame arrestor back on, it is not the cause of the problem & you risk explosion & fire running without it....
The Coast Guard will fine you if you get stopped as well....
I would suspect a clogged fuel vent.....
Or a water/ fuel separator filter that needs replacing, that is if you have one....
There are alot of diagnostic tests, but first I would change the above mentioned filter & see what that does to remedy your problem....
Secondly, try running it without the gas cap, to determine if you have a problem with venting.....
One other thing....
You mentioned that the coil was recently replaced....
Why?
& was the replacement the definately the proper coil?
Lastly, if the boat won't shift into reverse, the likelyhood that the lower shift cable is bad is very high & probably needs replacement......
The next test would be to use a portable gas tank with fresh fuel & see what effect that has.....
Generally a two minute run
under load should be sufficient......
Try these tests & post back with your results....
Post up the serial # orf your drive packageif you can as well.......Haut
