Answers to the questions in the sticky thread at the top of the forum are:
1) Performance issue you are trying to correct. – Our stainless prop has rock dings, and the hub is shot in our aluminum one. Both are three blade props. We would like to significantly increase hole shot with a new prop, even if we have to give up some top end speed.
2) Current prop manufacturer, model, aluminum or stainless as a minimum. – Unsure of manufacturers or models.
3) Current prop diameter and pitch (required). – our stainless prop is a (14.5 x 21-M1), our aluminum is 13.75 x 21
4) Wide open throttle RPM and speed with an average load (very helpful) – Typical top GPS speed at WOT is 45mph (depending on trim) at ~5200 rpm. The RPM range listed for this motor is 4500 – 5500.
5) Engine/drive make, model, year, and HP – Yamaha VMax HPDI, VZ150TLRB, 2002, 150hp, manufactured in April 2002.
6) Boat make model, year, length and weight- 2004 Yar-Craft Cobra 192DC, ~19 feet long, Manufacturers listed weight is 1600lbs, plus the Vmax listed above, plus a Yamaha T8 kicker, plus a 50-gallon fuel tank, plus 500lb worth of people.
We really want a new prop that increases our hole shot and gets the boat on plane as quickly as possible, but can also hold the bow in the air if needed in big water. We are thinking that a 4-blade stainless would be the ticket. However, we have no experience with sizing props, so we have no idea what pitch, diameter, or number of blades would be best for our application. Any insight you can provide would be appreciated!
OUR BOAT:
OUR PROP:
OUR BOAT:
OUR PROP:
