Please help the nooB
markmc
Bought a project boat that needs 2 of those swivel pin bolts that retains the steering assembly to the transom.
The threads appear to be like a 3/4" fine thread.
Where can i find a diagram with part numbers??
Thanks in advance!
btw. the boat is a 1986 four winns 22ft cudy with a sbc 5.7L if that helps..
Re: Please help the nooB
Thanks in advance!
Ayuh,... But what Outdrive,..??
markmc
The serial numbers are worn off, but it is a mercruiser single prop. i`m guessing that its a bravo 1..??
maybe.... but...
Manual 11 covers Bravo drives and the years it covers are from 1988 to 1998.. so...
We either need pics of the drive or some #'s. Is the drive and engine original to the boat?
markmc
maybe.... but...
I will post up some pics as soon as i can,, gotta work nights all weekend..
The outdrive and motor are original equipment..
Thanks for the help!!
vandentr
Mark,
When you finally figure out what specific equipment you're working with, I would HIGHLY recommend that you find as many of your parts through the various online retailers. I have saved a TON of $ by avoiding the local Merc. dealers!
Note: I'm not saying that you shouldn't by OEM (Quicksilver) parts, just that there are some serious deals to be had when you envoke some patience and shop around.
That said, here's a fairly comprehensive diagram site that should detail just about everything mechanical you can buy for your money pit, uh, I mean, project boat!
http://www.vanssports.com/pages/OemParts?aribrand=MRC
Select "Mercruiser" from the drop-down list once you identify your outdrive model and serial number. If it's truly an '86, I'd guess it to be an Alpha One, but you'll definitely need to confirm it. If that's what it winds up being, look for the "R/MR/ALPHA One" listings under "Mercruiser" (way down the list).
-TVB
markmc
Mark,
-TVB
Thanks Tom
I found a similar diagram that has the pin bolts i need. #4 and #5 of this drawing attached. could you please check the thread size and pitch then shoot me a pm @
EDIT: Email addys are strictly forbidden Mark. Please read our rules.
Thanks again!!
cpubud
if its an alpha 1 gen 2 they are called hindge pins and use a special tool .i just replaced mine while doing my bellows. west marine part #for the tool is 10532489 $19.48 the hindge pin # 10514610 $16.49 .
markmc
Here is a pic of the steering assembly with the missing pin bolt.
Maybe someone can identify the bolts i need..
Ayuh,... They are Mercruiser only parts,...
Those bolts can't be bought at yer local hardware store...
