PanamaRanger
- Joined
- Sep 3, 2009
- 19
I have a 70 HP Johnson about 1992, 3 cylinder with carbs. Had it gone through last year and carbs rebuilt. It has run great since then. Was running great first of summer. We were gone for a couple of months and it rained a lot. It is on a pontoon boat and rained where the gas tank is a lot.
When we got back we took it out. Now it runs really great at about 2000 to 3000 RPM for as long as you keep it there. If you give it wide open throttle it picks up to about 5100 RPM and runs just great for about 20-30 seconds then starts sputtering and missing. I thought it might be water in the gas. I have put Heet and also dry out stuff in the gas and run it for a couple of hours and it still does it. Back off the throttle and it runs fine again If you immediately give it more gas it starts sputtering again but if you wait a little while at a low throttle and then give it full throttle - it runs great for another 20-30 seconds and then starts sputtering again...idles great and runs at low throttle great. THANK YOU!!!
