Re: Please Help With My Trolling Motor Project
I would deffinitely shore up that base before you tear up your fiberglass. I would suggest some type of sleeve or blocking with bolts running thru the base of the motor into the rim of the boat. You will probably have to fabricate something. Being a carpenter I would probably use a section of trex or other composite deck material, drill two holes thru the motor base and thru the block. Then sand or grind thebottom edge to mate with the curve of the boat. Not sure what you have under the fiberlass to bolt to, or if you can access underneath the rim to install a nut and washer. It is an idea anyways.....
