Please help
toonin22
I have am 03 merc 20hp. My friend gave it to me with the lower unit disassembled. I put a new water pump, fuel pump and rebuilt the carb. I headed down to the lake and it started fine (one pull) Idled perfectly, Starts to accelerate but wont open all the way up. Any ideas??
aussieflash
Re: Please help
Did you do a link/sync/timing.Will need the manual for that.
toonin22
Re: Please help
I thought that was only with multiple carbs. I haven't check the timing yet.
ONERCBOATER
Re: Please help
link and synch is for single or multi carb.
what you are trying to do with link and synch is to have your timing in the right spot in relation to the carbs opening. this assures your engine will have proper fuel and spark in the right ratio and the right time... aka optimum operation.
sean
Silvertip
Re: Please help
Before getting all wrapped up in link&sync, why not check to make sure the throttle plate in the carb is opening all the way. It should be perfectly horizontal with the throttle set wide open. Is the engine actually running on all cylinders.
toonin22
Re: Please help
Hey thank you for your help. It was the spark plug on the second cylinder. Got it all timed. I see what you are talking about. Thanks again.
