I have been doing extensive research on adding a battery to my old aluminum boat. I am trying to figure out how to ground the negative terminal of thebattery. I have installed a trolling motor and a 12v plug to charge a phone but I am not sure how to ground the battery. I understand that I should run all wires to the battery terminals so where will it be grounded at?? Do I run a wire somewhere on the hull to the negative battery post?? Thanx for any help. By the way I have a small 5 hp pull start motor that doesn't need any battery power.
