Please learn from my mistake !!
SNye45
I used to store my previous boat at a RV/Boat storage facility as I didn't have the storage space at my house. For security I would take everything "loose" out of the boat including the battery, portable gas, fishing poles etc. My house was approx 2 miles away from the facility and so would put everything in the pickup bed for the ride home.
Being clever (or so I thought) to prevent the life jackets from blowing away I put them in my pickup bed "Storage Box", and to prevent the battery from falling over I put it in the box also.
Upon getting to the security gate I was told by a passerby that I had white smoke coming from my "Storage Box"
I learned physics very quickly that day. I quickly opened the lockable lid only to discover a small fire of burning plastic and rubber. Stupidly I had put the battery on top of a life jacket which (unknowingly) meant that it was just tall enough for both terminals come in touch with metal lid of the box.
I managed to smother the flames with a rag and found that the negative terminal had gotten so hot that it melted off and fallen to the box floor igniting the rubber floor mat and plastic packaging of lures that I had bought.
That battery was history while the replacement cost $80. An expensive lesson learnt. Now I have a different boat and have moved to a different house where luckily there is enough room that I can store my boat beside the house
david_r
Re: Please learn from my mistake !!
that could have been really bad........good thing someone was watchin out for ya..........
luv2b0at
That's a "shocking" story...
couldn;t help myself:p
ezmobee
That's a good one. I did sorta the same thing when I stored a deep cell battery under my back-to-back lounge seats. The metal bar that folds out when you fold the seats out flat touched both battery terminals. There's still all kinds of spark marks on that metal bar.
gpenton
Reminds me of my days in College as Stage Manager in the Fine Arts Department. I changed all of the nine volt batteries in the wireless microphones for the choir's performance that evening. I was also a member of the choir and just dropped a spare battery or two in my tux pockets with my car keys... needless to say, mid performance, something started getting hot in my pocket! No fire but it was pretty funny!
kenmyfam
Could have been a lot worse !!!!
Lesson learned eh !!!
Dave Barnett
An older friend of mine, when I was a kid showed me how to start a campfire using a battery and a piece of tie wire. Just make a small coil of the wire and ground out the battery terminals. The wire gets super red hot and will ignite tender with ease. I can imagine any metal would do this. It's a good thing the gasses from the battery didn't explode or fire get too out of control. Thank God no one was hurt and I will sure learn from this. Now that I think about it I have placed my battery in some bad situations. Thanks for posting this. Dave
Home Cookin'
I've dropped a 9 volt in my pocket--with a pocket knife. Once.
You can start a fire with a 9v and steel wool. It will burn. And the other day I was cleaning off a car battery (pos) with steel wool, arced a piece of metal and the steel wool caught on fire. Good to know in a survival situation, but not for everyday use!
gypsysoul
I had this happen on a bigger scale. I worked for a grading and paving company as a field mechanic. One job had a tree that they had to cut down. foreman said if I wanted it I could cut it up and take it for firewood. So I cut it up and loaded it in the bed of my mechanics truck. being a heavy equipment mechanic means the bed was also loaded with lots of other "junk". I pushed this junk to the front of the bed and loaded the wood in the back and on top of the junk. The truck had a gas powered air compressor also. so I always kept gas in the bed of the truck. After loading the wook I headed out to pick some parts up and head for home. About a mile away from the Caterpillar dealership I stoped at a stoplight and noticed smoke blowing past the truck. A quick check in the mirror and I could see the bed was engulfed in flames. I pulled over grabbed the fire extinguisher and went to work. some other motorist also stopped and where helping a homeowner string a garden hose out to the edge of the street where I was parked. What kept baffling me as I was digging through the wood to pull the gas cans out was why fire was "squirting". I got the cans out and safely moved and we knocked the flames down with the garden hose. afterward I discovered a porta-power pump had moved onto the positive post of a caterpillar 8d battery and the ram had found it's way onto the negative post. and that turned the hydraulilc hose connecting them into a roman candle so to speak. the hydraulilc fluid would heat up and spray out through the fire and make a flame thrower. luckily minimal damage to truck bed, but the thought of all the firewood mixed with this combination could have been bad. had I just jumped on the freeway to head home instead of stopping to pick up parts. The lesson from that was that now I am much cleaner with the bed of my truck (especially since it is my own truck now)
j_martin
I had a friend living in a remote cabin with a large family. With no utilities, they had a 12 volt battery to run a ham radio for communications. It was unprotected, just sitting on the floor. One day one of the kids came in and set a milk pail down on the battery.
It blew a hole in the milk pail, which made an interesting mess. I suspected the kid messed up his pants also.
I was able to weld up the hole in the pail, and I made him get a marine battery box for the battery.
