So tho boat I bought and have still not gotten to really take out is really starting to worry me. I have been waiting for new transom brackets for the power trim as the old ones broke about 2 mins into the first outing, so I have spent the time tinkering with the motor which seems to run pretty sweet now.
Anyway I went out today to start it up and double check everything as it hasen't been run for a few weeks. I start it up after 5 seconds of cranking and it idles perfect I had previously adjusted the shift linkages so I engaged both forward and reverse ( I didn't rev it in gear I just let it engage then sit at idle for 20 or so seconds). After 10 minutes of running I shut it down rather pleased with it, I jump down and turn off the muffs and !!!!!this is where I start to worry The inside of the prop is completely covered in milky sludgy oil. So as im new to boats Im praying this is common and there is no reason to worry.
Is there a chance that it is just the oil from the exhaust mixed with the cooling water???
