Hi guys it's the rookie posting again. So ad the title says my boat will not shift into reverse. A little back ground I recently pulled the transom off to replace the sea pump. Upon reassembling I noticed that I had a extra washer from my kit and did some research and found out it was the washer that goes over the shifting mechanism along with the rubber washer. So I installed it and reassembled the lower half. I thought all was good because the throttle up front felt awesome it had slack before now it felt like it engaged right away. But when I shift into reversed it locks into gear but I can't give t any throttle so I am super confused any help would be great.
