Plug Gap for 1967 9.5 HP Johnson
superflydudebike
Need correct gap for spark plugs. pulled plugs and one is fouled. Gap set at .025 on one and close to .020 on fouled plug. Seems too small. Anyone have access to correct gap? NGK B8S plugs Thanks.
superflydudebike
Re: Plug Gap for 1967 9.5 HP Johnson
Thanks for the quick response and the link. The link provides info on gap for my 6 HP Fisherman as well. This forum is great. I have a question regarding gap. If gap is too small what occurs? If too large?
F_R
The gap is related to the voltage required to arc (spark) across the gap. A narrow gap allows a weak, puny spark. A wide gap forces a higher voltage spark, but at the same time it is putting stress on the ignition system. Way too wide and the ignition system can't develop the voltage required to jump the gap. Remember, it takes a lot higher voltage to fire the plug under compression than it does out in open air.
ezeke
Don't think that I ever heard or read that expressed any better, F_R.
