followme21
- Joined
- May 19, 2008
- 65
So we have a 84 Century, Merc-5.7, that we have used now for 8 years..no major problems. I have been noticing that it seams to be taking on more water then I felt it should when I pull the plug, so last time out I decided to get a new plug and the base that the plug goes in. Ordered it, and installed it, when I took the old one out it had two wood screws that did not seam very tight and the third screw was a very long machine screw. So I siliconed up the new base and installed three new, a size bigger, wood screws, they all tightened up very good. The next day we went out and after about 2 hourse or so the boat was full of water, I'm talking full. After running the bilge pump enough to get the water level down below the crankshaft, I have never in the 8 years had to run the pump so was very excited when it actually worked, I was able to get back to the dock and onto the trailer, As it was heading up the ramp I could see water coming out from around the base of the newely installed brass plug base. Now the silicone I used was not marine grade it was simply a acrylic latex that says it is waterproof. When I got home and removed the base no silicone was there, it had all washed away. I plan on getting a good marine grade adhesive/silicone and reinstalling...Should I make a rubber gasket? or will silicone be enough????
Also regarding that machine screw that I removed from the old base...after inspecting inside the bilge area I found an electrical wire that appears that it was hooked to that srew..It looks like a ground wire that ran from the plug base up the the transom, there are a couple of other ground wires on the transom in the same spot... I will hook it back up but why does the plug base need to be grounded??
Thanks for reading and responding..Its a little long.
