DutchMerc
- Joined
- Jun 4, 2008
- 96
I have a 15" small boat, and i m nit sure if i have a problem. I am using a Mercury 402 Thunderbold outboard. On the back of the boat there are two plugs, one of them is at the lowest point in the hull, and the other is in the lowest point from the splashwell.
I noticed that the plug from the splaswell is below the waterline. Shouldn't I be able to drain the water from the splaswell when on the water? Is my motor to heavy, or do i have another problem? When on the driveway, i always take out both plugs to drain the boat, and from the lowest plug there is always some water coming out after a day on the water. (2-3 coffeecups). When i leave the plug out, it keeps dripping for several days before it stops. This is what i am worried about. Is this normal, or is this a case of wet foam?
