plug wires
machicj
Is there really any difference between automotive spark plug wires and marine wires? the local parts stores say they can't get them for boat applications. changin' plugs this spring and want to do the wires also. thanks<br />1985 wellcraft 170hp 4 cyl. merc.
Re: plug wires
You'll find the Ends are Different,......<br /><br />Both at the Plugs,+ at the Cap.............<br /><br />I've Already Tried that 1.......<br /><br />If you had an assortment of Ends,...... You could build set,.....<br />The Actual Wire IS the Same......
Reel Poor
Re: plug wires
Typically the componants of the wires are the same. The problem is in the application. Marine distributors are specific to their application. Most automotive sets that fit your particular engine will not have the right end on them for the distributor. Typically have to buy the marine set. You should be able to get them at a NAPA Auto Parts store. They sell marine parts.
KaGee
Re: plug wires
I bought the ACCEL brand which came with multiple style caps for the distributor. <br />You cut and crimp your own.
