Re: plugs & octane?
Yo, ZZ. Most of us get a "50:1" mix by putting a pint (16oz.) to a six-gallon tank or half pint (8oz.) to a three gallon tank. That produces a 48:1 mix if there are exactly six or three gallons in the tank. Depending on the tank, there is usually a little more or a little less. In my 24 gallon tank I use half a gallon of oil and 24 gallons of unleaded regular (86-87 octane). I get the tank completely empty by using an "auxilary" 6 gallon tank when it runs dry. Then I fill the big one completely.<br /><br />All that may be "so what?". If your manual says 3oz. per gallon (32:1) use a 32:1 ratio. I ruined a chainsaw that called for 32:1 by using left over 50:1 mix in it, so I feel qualified to warn you against doing the same to a much more expensive machine.<br /><br />One last thing: Make sure your manual is referring to U.S. gallons, not Imperial gallons. I don't know the exact conversion, but an Imperial gallon is more than the U.S gallon.<br />Good luck.<br />JB
