Mark42
- Joined
- Oct 8, 2003
- 9,334
I am putting a washer and dryer in a closet on the second floor of my home. Will install a stand pipe for washer and floor drain instead of a washer pan. Plan on using 2" pvc through to basement and tie into a 3" main pipe. I want to be sure that the floor drain trap does not dry up letting gas into the house. Can I join the floor drain and stand with a Y in the closet floor, and install the trap in the basement? That way both the stand pipe and floor drain will be protected by a common trap. There will be no other fixtures on this drain. The drain will also be vented through the roof.<br /><br />Is this OK with the UPC?<br /><br />Mark.
