Ply with resin on it?
pwfish1
My ply for the deck already has some resin coated onto it.
Can i add the matt over this to complete the glassing for the deck?
I can't imagine needing new ply.
Glass job will be done acording to instructions on "fiberglass info." for new decks.
thanks again
ondarvr
Re: Ply with resin on it?
Yes, but there are a couple of things you may need to do.
Did the resin you used have wax in it? If it did, the wax needs to be removed and then the surface needs to be sanded very well.
Without wax, if it only sat for a day or so after you coated it and it was kept clean and indoors, then you can go right over it. If it sat longer than that, or went out side, then it needs to be sanded before the glass is laid down.
pwfish1
there was no wax. has been on for a couple days. did sit outside in shade to dry.
wil this be light sand or heavy sand to really scruff it up?
thanks
ondarvr
If the surface will gum up 80 grit paper rapidly, then you should be able to go right over it. If the surface is rock hard and glossy, then sand it with some 36 grit lightly, no need to dig deeply into it.
rngale
i would lightly scuff it either way to make sure u dont have any little nubs sticking up that will make the glassing more difficult
pwfish1
according to the instructions in the "how to's" i will need 72 square ft of material and just over a gal of resin.
all i can find is pkg of 8 sq ft at most shops. where's the best place to purchase larger pieces??
thanks again.
Bob_VT
Check ebay ;)
escapade
how would you know if the resin has wax in it?? and if it does how would you go about removing the wax?
