plywood grade
bhm25
making a pot hauler box out of 3/4 BC grade plywood will be totally glassed with cloth on the outside and resin only on the inside...question is being that it going to be fiblerglassed is it worth the extra expence to get marine grade plywood ? thanks for any info
Chief101
Re: plywood grade
You'll be fine with BC, but I would use glass on the inside also... ;)
fishnfiend
Re: plywood grade
Many pros use AC or BC, encapsulated in resin. As long as all sides (especially end grain) are fully covered, water has no chance of getting in. Might want to thin the first coat and use less hardner to get maximum absorption before you start laying cloth.
