Re: Plywood question
Hi all, I need to re-do some items in my boat. I would like to redo the helm and the passenger side. I am thinking about just using 3/4 outdoor plywood and using epoxy to seal it up. I am just going to put carpet over it anyway so it doesnt' need to be fancy. My question is what brand of epoxy do you guys recommend? Will I have any problems with the carpet adhesive sticking to the epoxy? Is plywood normaly what the helm is made of originally? Sorry for so many newb questions. I am just trying to get everything in order when I start this project as soon as the weather gets somewhat nice....Thanks in advance
I'm sure you'll get other replies saying similar things, but I'll start off. First, check the search box on this board for lots of threads on plywood types and uses. Summary: If you seal the ply, it'll outlast you.
Second, most people here won't recommend carpet because it tends to trap water in a boat, exactly where you don't want it.
Third, the proper kind of carpet adhesive (indoor/outdoor) will stick just fine to epoxy.
I personally use epoxy from uscomposites.com, although the west system stuff is standard (and expensive). There are lots of sites on the net to get marine epoxy from, and generally any epoxy labeled "marine" will work for what you want. The major difference is in price, although there are some differences in quality.
Depending on the original quality of your boat, the helm (console) may be made of plywood, marine grade ply, straight fiberglass, or some combination. Most of the ones you can buy nowadays are molded fiberglass.
Most people here building a console would build it out of ply and cover with epoxy or polyester resin. Depending on what you want for strength, 3/4 may actually be too much. If you cover the ply with fiberglass, a lot of strength will come from that instead of the wood.
Regardless of materials, if you want what you build to last, make sure any water that gets on it can drain away or dry up, and make sure it's completely sealed, right down to any screw or staple holes you put in it to attach stuff to it or mount it.
Erik
