Pointers on what to look for
petriw
We would like to buy another boat for fishing and for my family to have some fun on the water. We don't have a lot to spend so I can't afford to buy a $10000 boat and motor. I don't need a situation that will cause me a lot of problems. We need a solid combination that will hang together and that I can pull and launch with my Chevy Venture van.
Our lakes are on the rocky side so aluminum boats are popular. In the North our boating season is about 5 months long so the year of a boat and motor can be deceiving.
If you have some ideas about "solid" combinations please share your thoughts.
Thanks
Wade
fishingdan
Re: Pointers on what to look for
It all depends what is available in your area. No point in throwing out suggestions from our side. In the US, there are a lot of boats for sale at this time that are very nice in the 3000-6000 price level.
Careful towing with the Venture if this is your first time do so with it. You must have a transmission cooler installed and they mean it when they say that trailers with a weight of over 1000lbs need brakes. Be there and done that with a Venture. It is not very well suited for towning.
tashasdaddy
Buying a boat
1st you need to decide what you want to use it for, fishing, cruising, or water sports.
2nd how many people adults, children you want on board of the average outing.
3rd outboard, inboard-outboard, or inboard power plant.
4th Budget, what you want to pay, and what you are willing to pay, when you find
Exactly what you want.
You can hire a marine surveyor, to inspect the boat, or you can do it yourself.
You are mainly looking for soft spots in the deck, transom, cracks, all signs of a rotten, under frame. You walk all over the deck, that a mallot, or hammer with wooden handle, using handle, tap all over the transom, a shape rap is good solid base, a thud, is questionable base.
The motor should be clean, no spots where the paint is discolored, or pealing from heat, having run hot. (This part for outboard motors Compression should be atleast 100psi, and within 10% of each other,)
Spark on all cylinders, good pee stream, check lower unit for water in oil.
The overall condition of the boat will tell you a lot, as to how it has been maintained.
A 30 year old boat motor combo, may be in better condition, than a 3 year old.
BUYING A USED MOTOR
overall condition, condition of the place you are buying it from, usually tells you how they care for things. compression 100 + psi, and within 10% of each other, good strong blue spark, no water in the lower unit oil. look for discolored paint, (sign of over heat at
one time, also scarred up bolts, as why. have them start it. if they fail to put it in a barrell or tank, or on muffs, or in the water, to start it they don't know what they are doing. best yet is to take it for a 30 min to 1 hour test run. also if remote controlled motor, the controls should come with it.
