Points and Parts
Wave1960
Packaged with my new points. Should I recognize this and where it goes??
It's a wiper for the distributor lobes and there is usually a little bracket that it fits in. put a dab of grease on one end and inset it into the little bracket so it just makes contact with the distributor lobes. Some models use them and some don't. it yours doesn't already have one, it's not used. just smear a SMALL dab of grease on the lobes. It's to keep the rubbing block on the points from wearing.
gm280
Don't think more is better when you apply any grease/lube to the cam lobes though. If you get too mush on the lobes, it will sling off and can end up on the point faces and that is not a good thing. A mere little swipe of grease is all it takes. JMHO
