I'm trying to figure out the lack of spark on bottom cylinder on 1959 10hp Johnson. I have spark on uppper. I've put new points and condensers on both cylinders, new plugs, and the PO installed new coils and wires. The points for bottom cylinder are not lining up perfectly parallel (See photos). Is it typical to have uneven alignment on new points? Would this prevent spark even if the gap was set at 0.020 on the edges that are closest to each other? Actually, the old points and arms on this cylinder were uneven too. I've checked and there's nothing underneath the arms causing the misalignment. I could bend the breaker arm to line it up better but I don't know if that'll ruin it.
Also, I've been setting the points with the shift lever in forward. That seems to allow for the most movement in the breaker arms. With the shift lever in neutral, it prevented the magneto from fully turning. Was this the right thing to do?
Finally, the breaker points adjustment screw doesn't seem to affect enough movement in the points while adjusting, even with the other screw that holds the arm to the plate loosened up a bit. Is there a ideal number of turns out from fully seated that the adjustment screw should be set to achieve best points adjustment?
Thanks,
Thanks,
