Well, back again with a 3 hp question. I have a 3 hp johnson, no spark on the top cylinder, re-did the ignition (wires, coils, condensor, points, plugs), set the new points at .02, ran for a bit then it ran rough again and died out at low throttle. I rechecked the points and the gap has moved from .02 to about .03 on both points. I've tightened the set screws so it shouldn't be the vibration from running, but they won't stay in the correct place for love or money. I've re-set, re-tightened and tried again, but I must be missing something. Any thoughts would be appreciated.
