Polaris 700 won't turn left
Tcs17
My jetski won't turn left. It turns right but the jet won't move back when I try to go left. Made for quite the circular trip back to shore lol
Re: Polaris 700 won't turn left
Has the plastic 'cap' that holds the cable jacket to the hull fitting failed? Also check under the handlebars there should be a clamp of some sort that hold the outside of the cable in place, could have come loose. The cable outside covering may have worn a hole in itself from use & age, & that will cause the inside of the cable to 'flex' when turning left only.
