Polishing & Waxing weekend project
marekli
I recently purchased a Makita polisher that came with 2 pads (one thicker and wooly, the other thinner). I also purchased 3M Finesse polishing and Collinite wax (recommended by someone to me). Since I never have done anything like this (I am good with sanding wood but not with fiberglass) I spent an hour just trying out the thicker pad with the polishing compound on the side where there is a bit more oxidation. I noticed I was getting quite tired since the tool is quite heavy.The boat is covered usually on a trailer so most of the oxidation is on the sides just above the water line... how do you guys go about this, how many steps, how many rpms etc?
jakedaawg
Re: Polishing & Waxing weekend project
I'm sure you will get a lot of different answers. I do a lot of "wheeling and waxing" each seeason. I start with 2000 wet/dry paper to remove the heaviest oxidation. I then use the wool pad with 3M heavy duty rubbing compound. I then work with a foam pad and use other 3m compounds down to machine glaze II or III. Four steps. Some times you can skip one of the compunds. With the heavy duty I usually run about 900 RPM. For the machine glazes I step it up to 1100 or so. The fith and final step is a good marine wax w/HPDE or whatever the initials are. I happen to like the "Starbrite Boat Wax" with a foam pad.
do a search, this topic has been answered many times.
the amount of oxidation will determine your steps.
I myself do not polish higher than 1500 RPM on a 7" pad, or 1300 RPM on a 9" pad
