klos
- Joined
- Oct 18, 2005
- 209
I work on my fiberglass prodjects in a pole barn that is not insulated. I turn the heat up to about 60 deg. while I'm working. Then after all the fiberglass lay-up I try to get the heat up to 70 deg. for 30-45 min. just enough to start the cure. After that I turn the heat off to about 40 deg. I am wondering if that will affect the strength after completely cured. Thanks.
