jurgenscraft
- Joined
- Nov 6, 2004
- 227
The boat I have ,has polystyrene built in under the deck as flotation.I had a look under the deck via a large inspection hatch fitted right at the stern of the deck and every thing looked okay barring two or three square shaped pieces that seemed to be a little loose, Has any body had previous experience with poystyrene as flotation if so what were the experiences. I have no intention of removing the deck to replace the polystyrene with foam if the poly styrene is acceptable.I suppose a solvent like MEK or lacquer thinners can be used to desolve the polystyrene and replace it with foam or bilge pumps. But I would prefer to leave alone.
Kind regards William Wright
