pontoon bilge pump
Status
Not open for further replies.
tashasdaddy
have some minor leaks in my tubes. 10 gallons a day. so i want to leave it in the water for a while.
each tube has a drain plug, on the lower rear, of the tube. inserted a thread to slip, PVC adapter in drain. used 1/2 inch PVC tubing, up to the motor deck, for each tube, attached to a "Y" with shut offs, attached the "Y" to this pump. http://www.northerntool.com/shop/tools/product_16817_16817 then an overboard line. works great.
airacobra
Re: pontoon bilge pump
tashasdaddy - Do you have any pictures of how this is rigged up? How does this work? Is the boat still in the water when you hook up the PVC tubing? Any more info you have woul dbe great. Thanks.
lncoop
Sadly, tashasdaddy is no longer with us cobra. Are you having problems with leaky toons?
Mr Crabbs
Incoop, is there any information on Tashasdaddy? I only know him from reading old posts, more curious than anything.
EGlideRider
Same here. I've followed his posts for a long time.
5150abf
He passed away right before Christmas of this year, he is certainly missed.
lncoop
If you want to read some touching words about him check out Dockside Chat.
jusfloatin
I saw this thread post and thought I would click on it as it has been a while since I last saw a post from him.
I even had posted a question some time ago that I thought for sure he would post his usual honest and straight forward take it to the bank answer. I understand why.
God speed my friend, God speed.
Status
