pontoon boat motor mount bracket setting
saltidoc
I have a 2004 Bentley 24 ft. pontoon boat with a Mercury 115 4 stroke engine. I had hydraulic steering added and can't get my engine trimmed all the way up. How will the boat be effected if I change the location of the motor on the motor mount bracket?
rickdb1boat
Re: pontoon boat motor mount bracket setting
Are you talking about raising it up on the bracket? Or to one side??
saltidoc
Yes, I am talking about changing the position of the motor on the bracket, raising it up.
Reel Poor
Is the hydraulic ram and hose assembly interfearing with something on the boat limiting the range you can tilt the engine? If so, what is hitting/interfearing with what?<br /><br />Raising the engine would not be the ideal way to try to compensate for your problem. Raising the engine would most likely cause cavitation and lack of water flow for the engine cooling.<br /><br />Can you post a picture of the problem?
