Hi.
I'm repairing a set of pontoons and my next step will be to construct the deck. The pontoons are the type that are flat on top with a 1" lip on each side to attach to the cross members. I believe from my research that most pontoon boats use aluminum extruded "hat" stringers covered with 3/4" pt plywood. I'm wondering about an alternative.
I would like to use 4" x 4" pt wood posts for the deck framing instead of the hat stringers.
I realize that I would need to isolate between aluminum pontoon and 4 x 4 instead of between aluminum stringer and 3/4 decking.
That 4x4 s will weigh more. A 24' boat will need 13 cross members at 24" on center. I'm guessing extra weight to be 100 to 200 pounds.
That I may need to add an underskin to keep the 4x4s from constant soaking and drying.
That I should make sure the 4x4 are dried and straight (not warping like often happens when pt lumber dries.
But, is there anything very wrong about framing the deck this way?
Thanks, Andy
Thanks, Andy
