Pontoon hydrodynamics - pitch and location of prop?
bds1078
Hi,
Years of boating, but am new to pontoons. I'm learning the quirks of a displacement hull. Found a 1991 18' Fiesta pontoon in good shape with smaller 19-20" toons, overpowered it with a good running 1978 Mercury 90hp. No tach on boat, boat runs pretty good with light load, but with heavy load lugs (as expected) with the bass boat 19 pitch prop that came with motor. I am on the hunt for a 15 pitch to try it out, unless someone thinks that lower would be better?
Also, at medium to high thrust water goes everywhere around the 90hp, and motor seems to be pretty deep in the water, although it sits on it's factory transom. Cavitation plate sits about 3.5" below bottom of tunnel/transom. Would raising motor 2-3" make much difference, or would that be flirting with too shallow under thrust? I realize that the hull was not engineered to be a ski boat, and the 90 is oversized at high thrust, but the water pounding the underside of the floor and flying all over the lower powerhead is a bit puzzling. Boat rides level, and tilt angle doesn't seem to affect the splashing at all. Thanks, Brad
EGlideRider
Re: Pontoon hydrodynamics - pitch and location of prop?
A 13 pitch should be about right. Before you get too concerned about water around the engine observe other pontoons to see if yours is abnormal. The aquadynamics of a pontoon boat results in lots of turbulent water at the stern at high speeds. The extra weight of the 90 could be the problem so you could raise it about 3" and try it.
Good luck and check back in with your solution.
bds1078
Haven't got my 14x13 prop in yet, but I did raise the motor about all I could (2.5") and it made a world of difference. Who'd a thunk it? Ran great with with 19P prop, got about 26mph top end with a normal sounding rev, good hole shot. I think the 13P will still be handy when she's loaded to the gills. Thanks for the help!
EGlideRider
You had better soon get a tach and check the actual RPM's because I can almost assure you that the 19 is too much.
lncoop
Ninety on an eighteen footer with small toons? Don't have an accident or you'll be in deep doo-doo.:eek:
