Pontoon Sponson Dent
D
DJ
Guest
Re: Pontoon Sponson Dent
You really should not use heat since the log may be filled with foam. Also, heat can cause undue pressure inside.
If it were me, I'd try drilling a few holes and using an auto body fender puller. That is a device with a self tapping screw on the end of a slide hammer.
You will have to fill the holes with something like JB Weld.
