Pontoon transom crack
adangelo77
Hi folks. Wondering if I should be worried about these cracks in the welds, I know they need to be fixed but wondering if I could ride it out until fall.
Thanks!
Fairly typical of aluminum fabrications.------The stuff flexes and cracks.------Best to cut it all off and start over.
GA_Boater
It looks like a repair was attempted seeing some of the welds.
adangelo77
Yea we bought the pontoon last fall, just wanted to get some opinions on how serious it is
GA_Boater
It looks like they tried to weld on top of the original beads. I'm not a welder, but I know that never works on a stressed welded joint.
HotTommy
I wouldn't trust if if it were my boat. If you're going to continue like that for even a litle while, I suggest you secure the motor to some other sturdy part of the boat with a strong cable. That way you won't lose the motor when it fails. ... BTW, it is possible to replace the entire engine pod with a good used one. That might be simpler and more cost effective.
The motor is ready to go for a swim.------Take all the junk off and have someone build something beefier / proper !!!
ahicks
What would be interesting to me is knowing how those side brackets ended up being bent/deformed like that? Knowing that might go a long way here.
if you let it go until it fails, you will need scuba gear to retrieve your motor
the welds have been repaired twice in the one photo
take the boat to a competent aluminum fabricator....... and get it fixed
ahicks
I've helped people that have "been there, done that" with failed transoms. The motor won't be on the bottom in my experience. It'll be hanging by the cables..... and a real chore to get loaded on a trailer!
