Re: Poor mans trim tab question (see image)
RodC;<br /><br />The problem with adding fixed trim tabs to the hull is tha this constitutes a permanent change in the hull design. In order to eliminate the porpoising you will need to deploy the tabs at an angle sufficient to lift the stern and keep the bow from popping up. If for example you cruise at 27 MPH the tab adjustment needs to be set for that speed (deployment angle). However, speeds above 27 may show signs of excess stern lift and resulting bow down. This will cause bow steering and handling issues, and less speed at the top end. In other words, you will need to pick what suites your needs as well as possible, understanding that what ever it is will be a compromise. These types of tabs are on the market now.<br /><br />The larger you make the tab the more effective it will be - obvious - and the low end improvement (getting on plane and staying there at lower speeds) will be more responsive. However, again we have a compromise as the larger plate will also effect the cruising and top speeds more. <br />Improving your hole shot will take more deployment angle than eliminating the porpoising at cruising speeds. Therefor you will need to pick a median point. <br />Each and every time you load the boat differently, will also change the handling and need for more or less "tabs". <br /><br />If you do not have the money (About $140.00) at this point for Smart Tabs, then try the fixed tab idea, but make sure you can adjust them, and expect to make a few trial and error runs to fiind the best compromise.<br /><br />As an active system the self adjusting feature of Smart Tabs is what makes them so effective.<br /><br />One post suggests that you look at boat balance, and so would I suggest this, as what you are telling us sounds as though the stern weight is very high.
