I have a 70's series starflite 115 hp.<br />engine, ran great last year, this year, last weak as a matter of fact the engine idles great,<br />however you have to hold your breath when you advance the throttle and hope it doesen't die.<br />If you play with it long enough it will finally take off, then it sounds like it is loading up or something for a while a couple of seconds maybe then it will peg the tack at 6500 rpm and you have to pull it down to not over rev. it.<br />it seem like the mid range has no power at all.<br />mind you this is on a 15 ft. mod. trihull that was clocked at 56 mph. last year now it won't get out of its own way. any help will be greatly welcomed. also I have had about 15 or 20 parts stores give me different types of plugs to use<br />and nobody seems to agree on anything, I currently run champion l77jc4's any advice on the plugs ?? Thanks in advance Bill
