OK fellow sailors, my water flow problem continues. After a new impeller, impeller housing, and cleanout of the water jacket I still have low water flow from the Tell-Tale. On start up it takes about 30 seconds to start flowing and then it never gives a consistent flow. I did buy a low pressure water gauge to check the pressure. I have to find the right brass fitting/adapter to do the install on that this afternoon.
So where do a look from here for a source for bad pressure? Maybe the metal tube from the impeller housing to the block?
Steve
:facepalm:
Steve
