I have a 73 85hp evinrude when it is on the hose it pops out of the exhaust and breather idles down comes back up then it does it again every 5 to 10 sec its more out of the exhaust than the breather. When i raise the cold start lever and get the rpm up to about 1400 its not as bad.When i go to the landing it does it not as bad then when i go run it for a little while btw it runs perfect getting on step and at cruising speed bring it to idle its fine runs perfect.These are the things ive done so far rebuilt both carbs changed all fuel lines and put good s.s clamps new spark plugs water pump. Decarbed the motor. Any thoughts would be greatly appreciated
