popping rotor on 5.7
I sent out an earlier posting and go little help with my 5.7 Mercruiser dying on the lake. So I thought I would try again in regards to the distributor.
Does anyone have an easy way to pop the rotor out of the distributor. I thought it would just pop off but it does not. I am afraid to really lay into it!
Re: popping rotor on 5.7
Ayuh,... They're Glued on from the factory,... Bust it Off,+ replace it...
JustJason
Yep... as Bondo says... they are loctited from factory. Hammer and chisel time.
Don S
Be a little careful here guys. That sensor ring on the rotor will take out the sensor in the distributor if you get too crazy. Usually a couple of screwdrivers between the tabs and all the way into the plastic part and some prying will pop them loose.
QC
Manual says heat . . .
Don S
Heat works great for locktite, not so good with rust. I usually find rust as the holding force.
