Need help with 116 ranger cherokee to help eliminate porpoising. Boat has a 60hp mercurcy with t/t and 10/13 stainless prop. Cavitation plate is even with keel when motor is zero trim and boat level. This boat is flat across most of the keel and is 78" wide, no pad, basically a flat bottom. It really starts to hop when trying to run with bow up at wot. Have already put on a 300se sport stabilizer and had some success. Picked up better hole shot and stayed even on MPH. Motor is mounted to transom in center holes of motor mount brackets. Could move motor up or down but which way? Don't have a jack plate yet. Any help would be appreciated.
